1 - 7 of 7 Posts
Your RAM will have no effect on your CPU reaching 4.3GHz, just go with whatever 1.5v kit looks good to you and fits your budget. The Mushkin is probably the best buy of the ones you listed.
Just go what looks good to you, RAM doesn't affect overclocks noticeably, at 2Ghz+ its not going to matter at all IMO.
If you have the money, go with the Tridents. It doesn't really matter, but if you want the best, then you shall have the best if your wallet allows you.
Sent from my GT-I9100 using Tapatalk 2
1 - 7 of 7 Posts
