1 - 6 of 6 Posts
I've replaced my old psu with a new antec tp430. But it makes a very high whistling sound, a real headache sound
it seems gpu related. the moment the xp logon window appears, the whistling starts. this stops when the gpu is working harder, like with directx. once back to desktop, that sound is back too.
The old psu was only a 300 watt, but it worked ok, so 430 watt should be no problem.
Can I do something about it?
gpu: radeon 9500pro
moni: iiyama vm19"
mobo: abit kd7
Have you tried to open the case and pin point the noise? Also it might be a consciedence that the new PS went in and the 9500 started with it's problems. The replacement coolers for 9500 are cheap try to pick one up. I love the zelman all heatshink GPU cooler works great.
It took me less then an hour to install the Zelman.
Have you tried to disconnect each of the case fans individually. Or how about your CPU HS are you sure it's not the problem?
Also it might be a bad PS it happens. Not often with Antec but still??
I had a PSU that whistled like crazy but it was cheap POS and only did it when it went under load.
If this started after you put the psu in, then it's definitely the PSU.
1 - 6 of 6 Posts
