Originally Posted by Contagion
images not found buddy
just because I removed the back slash after jpg it said images not found.
now it works ,
http://img60.imageshack.us/i/jerapicture0001.jpg/
http://img268.imageshack.us/i/jerapicture0003.jpg/
Originally Posted by manolith
there was an update to age of conan a couple of weeks ago.. i had the same issue with my 285.. but it had to do with the dx9.. i switched to DX10 beta and it works fine.. you have to make sure that your shadows are maxed out.. pretty much everything has to be maxed out if not you will get very odd suqare patches of shadows and odd lightning effects. it might be a driver issue that nvidia needs to check out but after runing dx10 is perfect. BTW this is a masive game.. maybe you have corrupt data. reinstall maybe =(
since my pc supposed to run the game smoothly I switched to dx10 test from the game options and maxed out everything, graphics better but the problem is the same.
I just uninstalled and reinstalled the game few days ago, but ok will uninstall and install it again.
Originally Posted by angrysasquatch
RAM definitely solved it for me, try switching it out if you can borrow some off a buddy or something.
am glad you solved it, unfortunately I don`t know any 1 near who play games or atleast have a decent ram, so I`ll have to buy me 4-6gb depends on the budget, before that i`ll return the ram to it`s original stats before I overclocked it, maybe it`ll work out.
I remembered something, a week ago I was trying to play Lineage 2 (private server), logged in to the characters but the background is kinda missed up and I can`t see the character (though the menu I can see it) just 3d is missed up, I thought its a private server related issue, but now with age of conan I got the same issue when I log in to the characters screen my character and the background is missed up I just see, ah well it`s hard to explain I just uploaded the screenshot
http://img39.imageshack.us/i/dxprob.jpg/
also see the black in this cinematic intro
http://img199.imageshack.us/i/dx1m.jpg/
http://img199.imageshack.us/i/dx2.jpg/ <=- look at his right shoulder\\arm
http://img127.imageshack.us/i/dx3.jpg/ <=- look at the floor
seems like a format is needed, faster than trying for days especially that it seems it`s either a screwed up graphic card driver that uninstall reinstall simply can`t fix it, or dx10 problem which I can`t seem to find a way to uninstall it and reinstall it. am sad that am gonna spend 2-3 days reinstalling stuff again after the format. will post the result after am done.
