White is the New Black - A HAFX Build **UPDATES!**
10110 Views 72 Replies 28 Participants Last post by  jackeyjoe
Tearing down a perfectly good case and painting it without prior experience. What could possibly go wrong?
The Plan
The plan with this build is to move away from the conventional and now seemingly boring black case and give birth to a bright white case that can hopefully stand out from the crowd.
The HAFX will be mostly white, however red will be used as a hilight for certain parts as to spice it up. Hopefully it turns out as well as it has in my head.
Contents
1. Before shots of the case and current system specs.
2. Stripping and dismantling the HAF X case.
3. Prepping case for paint and painting progress.
4. Finished shots of painted case.
5. Re-assembled Case.
6. PSU Sleeving
7. Begin installation of components and water loop
8. Advanced cable management
9. Custom full acrylic side panel
10. Completed setup.
The contents are subject to plenty of order changes, but that's the planned order - for now anyway
Let's get into it:
Current Case and System
System Specs:
Intel Core i7 2600k
Gigabyte P67A-UD4-B3
Gigabyte HD6950 1GB
2x WD 500GB 7200rpm Raid0
2x2GB Gskill Ripjaws 2000mhz 9-10-9-27
Corsair TX650
Auzentech X-Raider 7.1 Sound Card
Here's the system currently sitting on my incredibly messy desk.
Cooling - XSPC RX360 Rasa Kit:
RX360 Radiator
X2O 750 12V Pump/Reservoir
Rasa CPU Block
Red Tubing
Black (painted white) compression fittings
Here's a pic of the water setup, missing the tubing and compressions due to their non-arrival yesterday afternoon.
1 - 20 of 73 Posts
The Work Area and Current Progress
Just starting to strip the case now, rivets need to be drilled off and then it's onto sanding and priming. Should be ready for paint tonight or early tomorrow.
Yeah, it's a pretty messy backyard thanks to our dog who likes to grab everything and throw it everywhere but I can work with it. There's also plenty of lighting available so I'll be able to work late into the night.
That's it for now, I'm now off to de-rivet and completely tear down the case now. I'll be back with more pics once that is completed.
Subbed, I'm imagining some real sexy stuff
Will sub in a minute, nice build.
Make sure the dog doesn't grab case parts
Sub'd, Lets see how this turns out.
Are you still doing the window mod?
As am I, not sure it has anything to do with my build though
Haha yeah, I think or atleast hope that the bench is too high for her to jump up on.
Yep - will pretty much be plagerising that part of your mod and applying to my own
Loved the look of a full acrylic window and will definitely make it a part of my build.
Subbed
cant wait !
Im getting the Exact same case
HAf X FTW!!!
Looking pretty good, subbed
Originally Posted by gaming96;13059034
Subbed
cant wait !
HAf X FTW!!!
More like HafX FTB (For the Blind)
6
About time for a little update I think
The sun may go down, but with one of these little beauty's there will always be enough light to go on.
Got the case all dismantled - only took about 20 minutes to get all the rivets out and that was with the annoying task of getting the rivet heads off of the drill bit
Dismantled Case:
Motherboard tray given a light sand to give the prime something to stick to. I could have taken all the paint off, but I would have been there for weeks.
And given a coat of prime, the flash does make the coat look more uneven than it actually is so I'm not worried. I'll definitely be taking more time with the actual painting coats, but for prime I think it's even enough.
Subbed, good luck with your indoor painting =)
Originally Posted by Gawdz
Looks insane man, i have always wanted a HAF X
Yeah, they're nice cases if you like the 'space age' look they employ.
Originally Posted by robbo2
Subbed. Looking foreword to this
Cool, thanks for checking in.
I'm not painting indoors?
Been 11 hours since the last update, but a mans gotta sleep. Here's a little pic to keep things ticking over.
Unfortuanetly the sun is sitting right behind the tray in the pic so it doesn't look as good as it should, still a couple of light coats off being finished I think, but it's coming up fairly even which is nice.
Nice bike in your second post, yours by any chance? I like the colour of the paint too, looks very cool and I think it'll turn out exactly how you want it
brb, off to order the rest of the sleeving, a waterblock and get some good double sided tape so I can finish my mod.
Nah mate, not my bike. It's my step brother's bike which is kept here despite him no longer living here. He's supposedly sold it to a friend who doesn't wan to pick it up
Oh nice, that's what I still need to order - sleeving. Not going to be cheap or alot of fun, but totally worth it.
Always seemed to find white as really ugly for cases, however I think if executed well I think it could be beautifull. It think my problem is all the white platic cases I saw as a kid.
1 - 20 of 73 Posts
