The first thing to check before purchasing any monitor/TV is whether it uses PWM for backlight dimming.
PWM can cause eye strain, nausea and headaches...
Explanation of PWM, when and why it is bad, and possible solutions
www.notebookcheck.net
At least avoid the low frequency PWM models.
Check the reviews, flicker free usually means PWM free.
The
Monitor Reviews: Best of 2022 is super complete, all important aspects are covered.
Other good sites:
Detailed reviews from a range of monitor manufacturers. A focus on gaming monitors as well as those suited to general-purpose usage, movies and colour work.
pcmonitors.info
Expert monitor and display reviews with in depth analysis, testing, results and measurements. In depth, thorough and experienced
tftcentral.co.uk
I hadn't thought of PWM being a problem... if I notice such symptoms I'll check and see if the screen I got is. But I don't want to check first, because that might induce placebo effects. LG does advertise many models as being flicker free, but not the one I just bought. I didn't figure it meant anything, because they didn't say what flicker free actually meant.
I got the 22MK430H-B today. I wasn't super pumped with the selection of small (24" at most) displays, and I was tired of looking. So I figured why not just buy a cheapo and then I can address this issue again in a couple of months, since a bunch of new models usually come out in the fall.
Super short review - All things considered, it's excellent. $107 on amazon for a 22" 1080p 75hz IPS display? I expected 3 dead pixels, weird backlight bleed, and a tilt adjust mechanism that just lets the screen slump forward. Nope, none of those.
I'll only mention the flaws:
- Stand and bezel look cheap - they're non-glossy and extremely simple. The bezel is, by modern standards, quite wide. On the plus side, there's only one logo cluttering the bezel.
- No height adjust
- Blacks on the bottom end do tend to run together. I can't tell the difference between 0%, 1%, and 2%. 2% vs. 3% is discernible.
- Same for red and blue. I can't tell the difference between 0% through 4% of pure red or blue. Green doesn't have this problem, and holds up all the way down.
This amount of money 10 years ago, even not adjusted for inflation, may be able to buy a 22" LCD monitor, but it would be an awful display by comparison.
