why 1:1?
519 3
Im just curious as to why I want to keep my RAM and FSB on a 1:1 ratio. I cant go higher than 200 on my ram with 3200, so why can't I just keep pushing my cpu and not push my ram any further? Ive got it set to 200 right now and my ram and system work fine, but whenever I go even 1 over 200 then it doesnt run stable/at all.
1 - 4 of 4 Posts
I think you should be able to get a few extra mhz out of your ram. Raise the ram voltage to 2.8v and try again.
Running 1:1 ratio keeps the CPU and Memory in sync, this way one doesn't bottleneck the other. This will offer better overall performance.
I second Evil...good suggestion!
The main reason people dont like running anything other than 1:1 is because AMD's dont like running ASYNC...
Decent PC3200 should OC to PC3500 speeds usually with no problems (maybe a little voltage...2.8 or so)
If you are running REALLY tight timings (like 2-2-2) you may want to try 3-3-3.
1 - 4 of 4 Posts
