1 - 14 of 14 Posts
I headed in game and it seems no matter what settings I run Fraps and the game at, it's choppy as hell.
I can understand an FPS dip and a bit of judder every now and then but the game will totally freeze for random time periods between say 0.1 seconds and a second. It's like I'm getting 1 FPS when recording...
Any suggestions?
Hard drive isn't fast enough?
Discussion Starter #6
Originally Posted by Fallen Angel -X
Drop recording down to half size perhaps?
The quality would be degraded.
Originally Posted by decompiled
Check out playclaw.
Thanks, I'll check some videos and give it a go
Not sure, I run it on a different drive to the drive I run my game on. (OS + Fraps on one drive and games on the other drive).
Could a CPU bottleneck recording? I'm running at stock at the moment...
IF it's a chip like mine it sure as hell can.
Your quad? It won't care. Unless you're trying to record something like BC2 or IV you'll have at least two cores sitting idle.
Discussion Starter #9
Check out playclaw.
Hmm, when I open PlayClaw it says "No audio devices detected" and won't let me record sounds.
Then when I try to open a game the game will just crash with a DirectX error
EDIT: Any other programs worth trying, or solutions?
if its loading to slow drop the frame rate to 30 fps if it still does it then it all depends on the computer your running
Discussion Starter #13
Originally Posted by Freaxy View Post
You said you were running fraps on a separate drive. Are you also saving the movie on a separate drive?
Yep. It saves inside the default Fraps folder on the separate drive.
I thought a quad core could handle fraps
I've tried all kinds of different frame rates
1 - 14 of 14 Posts
