1 - 20 of 29 Posts
The power phase lights go off after about 10 seconds and it will not post.
This is after I got it and it started right up but in my stupid I forgot to boot off disk to reinstall windows and it failed to boot into my AMD based Windows 7.
I tried only one ram stick using both and clearing cmos twice, it just won't post at all
What now
In before DRM or kill switch
Check your cable connections. I can't think of any reason why an old Win7 install would bork a board into not POSTing.
I've swapped out boards/CPUs several times without reinstalling windows. It shouldn't matter.
check wiring, including power connections and front panel button connectors
Originally Posted by BallaTheFeared;11984594
Is it a video card issue? I never got to try my gtx 470 since putting the water block on it, this is a first attempt.
The phase lights going out is what concerns me here
Shouldn't matter unless in mounting the block you damaged the card...and on powering it the 1st time, killed the board. I doubt that would be the case.
Check your cabling connections. If you have a PC speaker in your case, pull the video card out-and see if you can get POST beep codes. Or if you have a second card on hand plug it in.
Could be cold temp bug I suppose though I've never gone that far to see that...bring it back to normal temps-i.e. room temp and see. Eliminate as many variable as you can.
Might have been a bad connection, so heating it up might have done something, or just the movement.
Originally Posted by BallaTheFeared;11984721
I dunno, when I went to bios it was at 70C idle.
I put the block back over it and it was down to 7C almost instantly.
Gee golly dunno what I should do about this cold boot issue.
Damn it balla, looks like you'll have to mount your rad on/in the computer after all.
Discussion Starter · #16 ·
Indeed it is, all is well once I get it to post lol...
In my AMD based windows gonna install everything and flash the bios..
False alarm I guess, that is wicked high temps for a cold boot problem though
No sir! It just means I need moar vcore!
Yeah, thought the cold boot bug was pretty common knowledge for SB.. glad you got it sorted.
1 - 20 of 29 Posts
