1 - 9 of 9 Posts
i have tried all my compression fittings they all leak on that place and why!!!
i have o-rings on my compress barbs.
piccy and pelase make it bigger cause otherwise u wont see it.
ps. it eats your internet speed :
Two guesses:
1) Overtightening of the barb, causing a deformed o-ring, which can leak.
2) Tube is not cut cleanly enough (i.e. on an angle) to sit in the compression barb, which slowly leaks.
Now i can say again everybody got rep +++++++
*peep* mods i can't say even in peace i repped people t_t
Usually lurking
I would try to put teflon tape around the fitting, and if that doesn't work, make sure your tubing is cut straight. Also make sure not to overtighten as stated above you could mess up the o-ring.
Discussion Starter · #8 ·
revive the threaaad!!!
now the barb below is leaking dammm..
1 - 9 of 9 Posts
