IIRC spread spectrum has something to do with electrical interference, if enabled it can help, however for older gen chip, it was recommended to disable it for stability. For sandy brisge, it is recommended to leave it on unless you're are messing around with the bclk or if the bus speed is showing a lower value than 100 (99.8 etc).
