1 - 13 of 13 Posts
HWM Blackbox
Everest
I haven't tried anything except updating drivers - Windows says that the drivers are up to date though.
Thanks a lot
Well, I know for a fact that every graphics card I've owned downclocks until you hit something that requires it to kick up to full speed, its actually normal...
Right now, my 4870x2 is at 500/500, in game though, even something like Guildwars, it kicks up to the stock 750/900
GPU-Z is the best. Also you should remember that graphics cars usually have different profiles. At desktop it drops down to 2D clocks and when you load up a game or such it changes the clocks to higher 3D clocks.
Discussion Starter · #6 ·
so... it's not underclocked then. Kinda 'cool n' quiet' but for GPUs.
Thanks a lot. Very helpful piece of software. Fecking Blackbox!
rep+ to all.
Stock for its RAM should actually be 800, not 666 nor 333.
What do you mean?
Originally Posted by makecoldplayhistory
What do you mean?
BTW. If you use ALT GR + Printscreen it only printscreens the active window
He means that your 3D clocks for memory is 800MHz.
Discussion Starter · #8 ·
Thanks.
I was using the snipping tool... one of my favourite things with Win7
Thanks.
Wow, never tried that program before. Thanks
rep+ to all.
What do you mean?
This should be the specs for your card. Time to upgrade maybe?
http://www.nvidia.com/object/geforce_8600.html
Discussion Starter · #12 ·
Yep!!!
1 - 13 of 13 Posts
