Hi, yesterday i oced my 3770k to 4.5ghz, stable at 1.336v on prime 95 blend for 12 hours and it ran like a charm without a single problem.
I am using an asus p8z77-v le plus
Then i left after finishing the test to come home to a 'reset desktop' (nothing open due to restart) which really surprised me. after that i opened cpuz and realtemp to check stuff out and even after everything was loaded my cpu wouldnt go down to 1600mhz (speed at idle) and it wouldnt go below 1v (again, idle) it just sat at about 1.3__ volts. then i tried occt and prime 95 and during the test my computer would begin to lag
I went through all the setting and couldnt find out why, i tried voltage at manual and offset, changed power management options and everything, i changed everything to stock... and guess what? NO CHANGE
all the temps idled about 7 degrees hotter annd the voltage was at 1.2__ idle
Anyone know why this was happening?
