1 - 2 of 2 Posts
1. My internet speed has jumped nearly 30 mb/s. My downloads are extremely fast at @ 2.7 - 2.6 mb down. It wasn't always like this. I pay for 15/5 and a little while I go I used to get max 1.7 mb down.
2. Why does my router (d-link dir 601) slow down my upload speeds, they are usually 500kb up or 5mb/s when connected directly to the modem.
I doubt that your router is slowing down your speeds. you should try plugging directly into the modem and bypassing the router completely via an ethernet cable. then run another speed test and see what happens. A lot of ISPs also use dynamic bandwidth, meaning that ur bandwidth can jump around a bit and wont always be exactly the same. If hard wiring your connection still gives you problems, i would suggest you call ur ISP, because then you will know it isnt your router.
1 - 2 of 2 Posts
