1 - 11 of 11 Posts
ok guys i need help and i have no idea how to even describe the sound apart from crackling.
It happens intermittently at any time and has no rhyme or reason to it that i can connect.
can somebody help me out and listen to this noise and tell me what this problem is even called.
3800x
2080super
thermaltake 850W gold
x570 gaming edge mobo
if this is in the wrong section i can move it?
What is your
vSOC
vDDP
vDDG IOD
vDDG CCD
Voltages set at ?
You can check using Ryzen Master, vDDG will only show you one value so post that one
And at what frequency is your IF (Infinity Fabric) running at ?
vSOC : 1.05
vDDP : .95
vDDG IOD 1.0
vDDG CCD 1.0
3800mhz : 1900 1:1
If you drop to 3733/1866 or 3666/1833 1:1 does the audio problem stop ?
Rig Advisor
My 486 used to sound like that when it was trying hard to process something.
#1- Where do YOU think the noise is coming from?
#2- When did it start? After any configuration changes or has it always been there?
Discussion Starter #7
#1 i have no idea, literally have opened up the case and put my ear close to everything and it just seems like the MOBO
No changes that i can think of
Discussion Starter #9
Sorry, I misunderstood your issue.
I assumed you was hearing this sound in your speakers/earphones.
Now I have understood it is coming from the motherboard.
That means it is just "coil whine"
See link below
https://www.ekwb.com/blog/everything-you-need-to-know-about-coil-whine/
No sorry i didn't explain it better, its in the case not in my headphones, its ******* annoying.
I don't know if it is my mobo just sounds like its my whole pc, no matter where i put my ear it is just as loud.
I hope its not coil whine because from that article it says there is no FIX
edit: i put my headphones on so i dont have to listen to it
1 - 11 of 11 Posts
