I have an old bunch of wifi cards (a/b) that I can make work on Linux using ndiswrapper and the windows driver. It is very easy to do.
http://www.overclock.net/linux-unix-...ht=ndiswrapper
The guide is set for Ubuntu Linux, but the software is the same for all distros. Whenever there is a version number, use the latest, not necessarily the one given.
Now, to directly address your question, any wireless g card can use this procedure too. Linux recognizes a few wifi chipsets, so if you want easy set-up, you will need to find the particular chipset in the wifi card you want.
