will be plenty
Originally Posted by bk7794 ![]() the Ea500 was considered but I don't know which version it was but this cooler master I kinda liked the antec i like because it has 8 pin |
Originally Posted by shinji2k ![]() That Cooler Master is in the same boat as the 550W you linked to earlier. It's another overrated model. It is basically a 500W unit with a 600W label on it. The first Antec link goes to the Antec section, not a specific PSU. If it was to this one: http://www.ibuildcomputer.com/cgi-bi...WSAT&p_vlt=yps then it's decent. I would take the EA500 for $5 more though. The EA500 for $73 seems to be the best deal on that site and it would easily handle a 4850. The Truepower Trio 650 isn't all that good. Antec cut too many corners on that unit and it isn't as good as it should be. |
Originally Posted by shinji2k ![]() Hmm, there's nothing that really stands out as a great deal. If you don't mind MIRs, the OCZ SXS is a decent budget unit: 500W and 600W. Also decently priced after rebates are the Corsairs: vx450, vx550 and tx650. Also the BFG LS series is good: 450W. Since I know many people don't like rebates, the best deals I can find would be these Antecs: EA500, the modular Neo 500W or the EA650. The 450/500W units are fine for your setup, but since you had asked about the TP Trio 650W I wasn't exactly sure what you were considering so I included some higher watt models. In terms of quality it goes Corsair = BFG > Antec > OCZ so buy the best one you can afford. Buy.com has better prices on the BFGs (like this 450 and 550) and Corsairs (vx450 and tx650) but then the free shipping is a little on the slow side and their customer service isn't near what newegg's is. Sorry if this was a little long winded. I hope I gave you enough options ![]() |
