1 - 15 of 15 Posts
Just finally completing my build and thinking of putting another Gigabyte card in to make 2 instead of 1.
Will the Cooler Master V Series 700W 80Plus Gold Power Supply be good enough to run two?
I wont be overclocking at this stage, and if I do an upgrade power supply then if needed.
thanks in advance.
Like I said i wont be overclocking them or anything..
Just want to know if it will be suitable to run both, will only be playing games and some video editing but not too hardcore?
Done
Originally Posted by brapster View Post
yup sure do, so preference isnt to change it.. if I dont have to.
right, that makes sense then. Not too sure if the v700 will cut it for video editing. Im pretty sure Premier can load your cards @ 100% right?
Stock SLI GTX 780ti with a factory overclock will be fine on the V700. A factor would be which cpu and what kind of overclock on it. But even a lightly overclocked 6core SB-E will ok with this system and psu.
If you do decide to do it with your 700w psu be sure to let us know if it was able to handle the load.
I have a 700w psu with a single GTX780 and I'm planning to add another one soon would love to keep it.
Discussion Starter · #11 ·
full system specs below, just looking to add the extra graphics card..
No Type
1 Intel Core i7 4930K
1 ASUS P9X79-WS Motherboard
1 Kingston HyperX Beast KHX21C11T3K4/32X 32GB (4x8GB) DDR3
1 Corsair Obsidian 750D Case with Window
2 Seagate Barracuda 2TB ST2000DM001
1 Cooler Master V Series 700W 80Plus Gold Power Supply
1 Samsung 840 EVO Series 250GB SSD
1 Corsair Hydro Series H60 SE CPU Cooler
2 ASUS VE248H 24in Widescreen LED Monitor
1 Gigabyte GeForce GTX 780 Ti 3GB OC Edition
1 Windows 7
1 ASUS DRW-24D3ST 24x DVD Writer
2 Noctua NF-S12A 120mm PWM 1200RPM Fan (2 x FOR TOP)
1 Corsair Vengeance 1500 v2 Dolby 7.1 USB Gaming Headset
1 Corsair Vengeance M65 FPS Laser Gaming Mouse Military Green
1 Corsair Vengeance K95 Mechanical Keyboard
No Type
1 Windows 7
You're good adding another GTX 780 TI. Just overclocking is limited somewhat, which you said already you won't be doing.
Reactions: brapster
v700 is a solid psu and it won't let you down on what you want out of it.
I say use the v700 for a bit first and see how it goes. Your system won't blow up or anything, just shutdown if the load is too heavy.
Really, the v700 is a beastly quality unit.
1 - 15 of 15 Posts
