1 - 4 of 4 Posts
Will my 3d surround still work if I connect middle monitor to a splitter and the other end to a projector in my living room with a really long dvi cable ?
Or can I just use hdmi to plug into empty slot of my gpu?
You wouldn't be able to use the other hdmi if you're running surround. You would have to add another gpu, or disable surround. I'm not sure about the splitter.
Tech Enthusiast
You have two GPUs...so why even use a splitter?
I think he wants his center monitor cloned to a different device.
1 - 4 of 4 Posts
