1 - 13 of 13 Posts
does anybody know will a 140 fan fit a antec p180 series case?
like a big boy?
i am fed up with the tri cools crap.
tia
- 1 rear (standard) 120mm TriCool Fan with 3-speed switch control
- 1 top (standard) 120mm TriCool Fan
- 1 lower chamber (standard) 120mm TriCool Fan
- 1 front (optional) 120mm fan
- 1 middle (optional) 120mm fan to cool graphics cards
Strait from Antec's site. It's all 120mm fans so no you can't do a 140 (unless you use something like a Noctua P14, or Thermalright TY-140) but 120's gallor.
Senior Member
He said you can mount 140mm fans that has 120mm mounting wholes.
That means that you can install Noctua P-14 and Thermalright TY-140 in it.
The front might be hard to fit one in but the rear and top should work.
It's been a bit since I had my P-Series case; but I don't think a TY-140 or P-14 would fit in the front or the rear. But top should be fine.
Senior Member
Had my P182 open now and indeed it can be tricky to get it to fit in the rear as well.
Senior Member
I haven't installed any in the front since I have a lovely P12 there but space seems very sparse there.
Discussion Starter #11
1 - 13 of 13 Posts
