It looks like it should...I would just measure like you are doing but I think it should...how much room does your 4850 have? but it will be a tight fit
Originally Posted by noobclocker1277
what a **** i am...if i put it in the top slot it will just go in to one of the optical bays so it will fit easily
If you want it in the bottom slot, you can just cut a little piece out of the back of the HDD bays and slip it in. That is what I had to do on my old case.
Plenty of room on my new Tt armor.
1 - 19 of 19 Posts
