Don't waste your money on a 1GB version, buy a 512 version, or get a GTS 450.
Look at my sig rig..
But if you go with that, it won't bottle neck..
Problem is I haven't found a GTS450 low profile card and also the PSU isn't that powerful.. And I think it would be overkill for 1024x768.Originally Posted by Speedster159;13070553
Don't waste your money on a 1GB version, but a 512 one and get a GTS 450..
True, but the GTS 450 comes with one of those, 2x 4pin to 1x 6pinOriginally Posted by dudemanppl;13070560
I'm thinking he probably doesn't want to buy a separate powersupply, which explains why he would be using a GT430. Go for it, if it doesn't run, lower the quality.
Expect if your mom decides to buy a 1080p monitor.Originally Posted by donkru;13070568
Problem is I haven't found a GTS450 low profile card. And I think it would be overkill for 1024x768.
Then why not just OC the GT 430 to the GT 440 clocks?Originally Posted by Booty Warrior;13070590
You could go for a GT 440. http://www.newegg.com/Product/Product.aspx?Item=N82E16814162076&cm_re=gt_440-_-14-162-076-_-Product
It's essentially a 430 with higher clocks and GDDR5 VRAM. At that res, it should give "playable" fps on low settings.
GDDR5 VRAM won't be bottlenecked quite as badly by the 128bit bus width as DDR3. Whether that even matters with low end cards like this I have no idea though, haha.Originally Posted by Speedster159;13070595
GDDR5 ram on 440Originally Posted by Speedster159;13070595
I don't think that would matter...Originally Posted by Booty Warrior;13070606
Still, they're almost the same price anyway.
that card is to long, In the case it has to be only 1/2 inch longer than slot, Max. It's a small HP case. not much room in there at all. Also I doubt mom will be getting a new monitor without upgrading her pc. She follows a similar upgrade cycle to me just instead of every 3 1/2 years that I do she does every 5 years, and then only a $500 budget. She only does pogo and paper work.Originally Posted by Booty Warrior;13070590
Originally Posted by Booty Warrior ![]() Ah here ya go, some footage of Crysis on a GT 430 (1600x900): http://www.youtube.com/watch?v=YVkZoSdfajk |
Originally Posted by Booty Warrior ![]() Too long? Are you sure? It's only 5.7 inches. I'm not seeing any 430s that are shorter. |
Yeah you should be fine with a 430. Looking at other YT videos it actually performs pretty well for an entry level card.Originally Posted by donkru;13070671
Sorry I meant tall. I need a low profile card that is only as long as the slot. I have been looking but I haven't seen many different cards available, I found a 1gb sparkle that would fit for $60. I wish i could find them used for cheaper.
Edit:
That play through has 83% more pixels than 1024x768, That must mean that at the lower resolution I should be very playable. Im sure it can max out all the source games.
