will a mugen 2 fit in an antec 300 case easily?
359 Views 2 Replies 2 Participants Last post by  dumdedum
Was wondering if I will run into trouble fitting a Mugen 2 in an Antec 300 case?
1 - 3 of 3 Posts
Nope, it'll fit just fine.
The only problem is you'll have to take out your mobo to re-mount it. So get it right the first time
Unless you mod, then you can cut a CPU hole and not worry about it.
1 - 3 of 3 Posts
