1 - 6 of 6 Posts
i was wondering if Big Typhoon will fit on my motherboard i have a asus A8N PREMIUM and a thermaltake shark case i think i should be right just checking before i buy one
just thinking about the heatsink fins on the chipset heatpipe next to the cpu
ahh... i see what you're saying. I think it should fit as the Big Typhoon is tall enough it can clear most things on the mobo. the big typhoon comes out farther than my 7800GT. I can't promise you that it will fit, but just trying to gague where the fins are by looking at my A8N-SLI Deluxe it should fit.
red arrows, you should have an tiny bit of room between your TT and your card. Ram slot one will have tight room for ram, but you should be able to slip the ram in. My old epox was much like yours. things will be tight, but should fit.
1 - 6 of 6 Posts
