1 - 5 of 5 Posts
Depending on how deep your pockets are, you can easily get your rig into a HTPC case.
I know that Silverstone makes a few full ATX desktop / HTPC cases.
Also Lian Li has had some for a while, such as the PC-C33-B or the PC-C34F-B (some of the older ones are more reasonable if you can find them). Zalman also has some, but they are always expensive (+$300)
Most full ATX desktop cases have room for at least one OD and 2 HDs, some, such as the PC-C34F-B actually have a small 4 bay hot swap bay.
Others might have a display or other feature depending on what you want / price your willing to float. Good luck on the search.
1 - 5 of 5 Posts
