Will I notice the diffrence?
514 Views 11 Replies 9 Participants Last post by  The_Rocker
Hi there, i have recently been using a audigy 2 ze software modded to an x-Fi. I am about to get an X-fi extreme gamer. Would i notice i big diffrence?
(I am using the Fatal1ty Headphones btw)
Thanks and +rep for help as usual
1 - 12 of 12 Posts
Yes, especially for games that support the newer EAX effects
Edit: Almost forgot, for music, put it in Audio Creation and select bit-matching. Sounds soo much better
Yes the Xfi will definitely sound better.
Don't hear any difference.. But I'm using ASIO so will this effect it?
BitMatched playback sounded no better at all when I had my Prelude.
To be honest, an Xtreme Gamer X-Fi probably won't sound any better than the Audigy 2 modded to X-Fi in music.
In games you might notice a small difference, but not much. EAX really isn't amazing.
x2. Totally agree.
But how about a real X-Fi card like the Elite Pro or the Fatality Platinum?
for music listening I dissagree
I have the same card with the xmod.
the Best Thing for those are the ASIO drivers (music only from my experience) the SQ improvement is eargasmic - it makes siberias sound like grados (sr60) (metaphorically) > and whatever you connect to it - speakers etc...
edit. I have the SE version
They are more of an upgrade, the Prelude is pretty much the best X-Fi card.
The only real upgrade from that Audigy dude is to go onto something a bit more towards the top end... I.e an X-Fi Elite Pro or an ASUS Xonar DX or better.
1 - 12 of 12 Posts
