Hi there,
I have a problem getting all my parts for the water cooling setup.
I have obtained the following:
CPU block - EK Supreme HF Plexi
Chipset Block - Swiftech MCW30
Res - Swiftech Micro V2
Rad - Black Ice GT 240
I'm on the hunt for pump but to no avail - i could get EK Water Pump EK-DCP 2.2 as is the only available in stores for now.
The question are:
1) Whether only with this rad will i be able to cool my system in the sig or i should look for another 120 to add or replace this one with 360?
2) Will ,the pump above, be sufficient for this setup or i should look for other?
3) What order to put the components - for now i was thinking Res>CPU>Chipset>Pump>Rad?
Cheers mates and help will be appreciated
The question are:
