Will it fit?
445 Views 9 Replies 4 Participants Last post by  Crooksy
Xonar D2 (PCI) In the Asus Striker II Formula 780i motherboard whilst I have 2x GTX260's in SLI (Top and bottom slot.) I have a free PCI slot so i'm guessing it will. However not really sure how thick the sound card is? Is it just a standard single slot?
EDIT: If I buy a D2X version which has the PCI-E connection will it fit up top above my primary graphics card without hitting into my RAM slots?
1 - 10 of 10 Posts
Yes it should, I have the D2X and its width is less than 3/4 inch and sits in the PCI-E x1 slot above my 8800GT's. It hits the ram clips for me so you might want to see if your board has more room. It's a great card though
. Make sure you have a floppy power connector too.
Oh right, I have heard of the floppy power connector but havew never used one. Does my 750w Corsiar have one? Or will I need an adapter.
bump.
THATS WHAT SHE SAID!!!!!!!!!!!!!!!.... sorry I couldn't help myself.
...tumbleweed
Yes, your TX750 does have two floppy connectors located at the end of two of the Molex cables.
The D2X is a pretty long card and generally it doesn't fit well into motherboards with PCIe x1 slots above the video card. On my friend's EP45-UD3P, he has to use a PCI-e x8 slot for the D2X.
Oh right glad to hear the PSU is suitable. I thought it would be
Yeah i just saw my friends xonar and it's pretty big... Think i'll just have to go with the D2 with the PCI interface and but it inbetween my GPU's. What a beasty sammich that makes.
+reps.
1 - 10 of 10 Posts
