Will my CPU bottleneck a GTS 250?
2030 Views 10 Replies 7 Participants Last post by  Shooter116
It will be combined with my current sig rig. +rep
1 - 11 of 11 Posts
It will be bottlenecking it a tad, but not to much - especially if it's OC'd - so all in all you should be fine and all good to go imo.
Originally Posted by christianex
it will be bottlenecking it a tad, but not to much - especially if it's oc'd - so all in all you should be fine and all good to go imo.
+1.
It is not OC'ed at all. In fact I can't OC it because of my HP motherboard. So my entire system is stock.
You'll be fine. The higher resolutions will put more of the load on the gpu
this
my friend has a 5000+ X2 @ stock and a 8800GT oced and scores 9k in vanage (with physX on) if that tells you anything.
It should be ok, a mild bottleneck yes, but tolerable.
You'll definitely see it at higher resolutions / more demanding games, but overall a great upgrade from an 8600
Thanks for the replies. I'm gonna go with it. I plan to upgrade to a Phenom II and new MB soon enough anyway! +rep to all that gave input
1 - 11 of 11 Posts
