1 - 6 of 6 Posts
i am getting a new comp in a few days and i will get my new ram a few weeks later, so i was wondering if i could use my old pc-3200 ram sticks (2 gig) for now until i get the new one... is it possible?
is it ddr or ddr2? only ddr2 will work with it.<br />
<a href="http://usa.asus.com/products4.aspx?l1=3&l2=11&l3=307&model=1295&modelmenu=1" target="_blank">http://usa.asus.com/products4.aspx?l...95&modelmenu=1</a>
...I think that you will need at least DDR2 533 for this board to POST...What you described is standard DDR, not DDR2...So to answer your question...No the RAM will not work<br />
<br />
Hope this helps
You will need new RAM... otherwise you could always go with an AMD socket 939 build to keep that 2 gigs <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
You won't be able to get Conroe though, if that's what you want..<br />
<br />
If you're getting the P5B-Deluxe though you will need DDR2
Corsair or Ocz, both have some good value series. Both clock pretty good, and produce decent scores on Sisandra
1 - 6 of 6 Posts
