1 - 10 of 10 Posts
I am hoping that between the fact it is open air and that I can undervolt, it should be okay, and hopefully at relatively low fan speeds.
Worst case, I guess I could air cool the CPU and use both 360mm radiators to cool the 4090.
And on one hand, I can appreciate the cooling capacity of external radiators like the MO-RA3, but on the other, I am partial to the aesthetics of all internal radiators.
I would like to comment but no experience with a high power gpu. I have i9-7980x plus Rx580 gpu. 2 rads were enough but I added another 360 rad and the temps remained the same. For me, you may need 3x360 rads but if you dont have room, can you stack 2 together? With 3 rads, you may need 2 rads just for the gpu and one rad for the cpu, two circuits. I saw the stats on the 4090 and its going to be hot.
hope this helps.
I have one 360x45 and one 480x45, should be fine together with the cpu. How thick are your rads? I don’t think 2x360x30 will be enough unfortunately depending on the cpu you’re trying to keep cool and quiet as well of course.
A RTX 4090 can pull like 450W. The new card is a power hog beast. The normal heat sink and fans are 3 to 4 slots thick. I have a RTX 3090 with a 12900KF and two 360 rads and they cool both fine. I would think if I had a 4090 in this loop my over all temps would only go up maybe a few degrees if that. The fan type and speed matter a lot dealing with heat. In you have push pull or just push or pull. Also the type pump as well. A D5 to me is a must. Also the thickness of the rads.
I had a 3080 and a 5800X running off just a 360 (thick one in P/P) crammed in a modded Silverstone GD08, which had awful airflow, and with a small GPU undervolt it was still perfectly manageable. I was only running fans at about 700 RPM and GPU temps were in the low 50's max.
Now all of that is in an o11 mini with a 360 and 280 (360XE and 280 SR2, just in push) and with 800 RPM fans GPU temps barely get into the 40's. I'm going to be putting a 4090 in this same rig, and while I'll do another small undervolt, I expect it to be fine with fans at sub-1k rpm
We will find out but so many factor have to be taken into account outside of pure radiator. I don't think we can plan ahead just if situation comes you need more rads, then you figure out the solution.
Discussion Starter · #9 ·
Yeah, it's really hard to tell right now because specs alone don't give us the full picture. Will be clearer in the coming months.
PC Evangelist
Should be enough. I have 12900K @ 250W and 6900 XT @ 500W and 2x360mm is fine. You can handle about 1000W with 10-15C delta.
Reactions: silencefreak
1 - 10 of 10 Posts
