1 - 3 of 3 Posts
my current case is the thermaltake overseer rx-1 I currently have the corsair h100i I was not able to fit the corsair h110 280mm radiator but I read on a forum that if your case supports a 240mm radiator it will support the nzxt kraken x60 with a 280mm radiator is this true ?
Originally Posted by Legonut View Post
No this is not true, the Kraken X60 uses the same hole spacing and is the same size as an H110.
thanks I was about to return my h100i and get the nzxt kraken x60 . are there any 240mm liquid coolers that will perform better then the h100i ?
1 - 3 of 3 Posts
