I was wondering if yall could tell me if this
motherboard:
http://www.newegg.com/Product/Produc...82E16813188026
Will be able to use this memory:
http://www.newegg.com/Product/Produc...82E16820146112
I ask because it says that the memory standard on the FTW mobo is 1066, not 667. If the motherboard will accept that RAM, then how fast do you think i could get that memory up to? May sound like a strange question but that is because i am slowly piecing together a system over time as i come into the proper funds. So the reason i would be asking if that memory would work is because i do know that it will work on the motherboard that i am using now. Then when i get enough money to buy the 750i, i simply pull that RAM out of the old mobo and put it in the 750i, then overclock the RAM. May sound like a strange way to build a new system, but i am afraid that it is my only option as i go to school and can only work part-time. (for now)
I also have another unrelated memory question, that has nothing to do with what i just asked. What is dual channel memory? Why is it better? Why would this board be at a disadvantage because it does not support dual channel memory?
http://www.newegg.com/Product/Produc...82E16813188021
motherboard:
