Will this ram work?
406 Views 7 Replies 4 Participants Last post by  Dopamin3
This ram says "Dual Channel Intel Core i5 & Core i7 CPU for P55 motherboard", it just confuses me a little. Is the ram dual channel compatible with only i5 & i7, or is it compatible with all cpu's/all dual channel mobo's? Here's the build I'm getting ready to buy, and I'd like to change the ram.
RAM - http://www.newegg.com/Product/Produc...Tpk=20-231-275
Case - http://www.newegg.com/Product/Produc...82E16811119196
CPU + MOBO - Combo - http://www.newegg.com/Product/ComboD...t=Combo.295032
PSU + Video Card - Combo - http://www.newegg.com/Product/ComboD...t=Combo.298969
RAM - http://www.newegg.com/Product/Produc...82E16820227307
HDD - http://www.newegg.com/Product/Produc...82E16822152181
$565.04 shipped - $475.04 after $90.00 in rebates
1 - 8 of 8 Posts
That mobo is DDR3 compatible so the RAM should work fine.
Yes but will it use dual channel mode without a problem?
As long as you put the RAM in the right slots.
Originally Posted by skitzogreg
Daveros, your avatar is epic.
I like you already.
tyvm rep+
Read the description on the product page of the memory: "Compatible with Dual Channel Intel Core i5 CPU for P55 chipset motherboard, Dual Channel Core i7 CPU for P55 chipset motherboard, and AMD AM3 Platform."
Just a warning though: most Ripjaws kits do not play well on AM3 platforms.
But you should be fine at 8-8-8 1333mhz
1 - 8 of 8 Posts
