It's an FSP OEM unit, which is ok but not great. It will probably work, but I don't know about long-term stability.
Originally Posted by Phaedrus2129 ![]() Of course not. But the OEM determines the build quality usually. Take a Corsair design and give it to both SeaSonic and Huntkey, which PSU is going to be better? Almost certainly the SeaSonic. I really don't know much about this unit in particular, and that makes me cautious. If it's using cheap Chinese caps then odds are it's quite derated already. The efficiency looks pretty low (63%), which says to me that it is using low quality caps and other components. And in that case I would be very worried about it not being able to power a 5870 and the rest of the system over the long term. It does claim OVP, OCP, and SCP which are the most important protections imo, so it probably won't fry his system if it dies. Still, I wouldn't risk it in his shoes. Data: http://www.fspgroup.com/Catalog_PDF%...P550-60PLG.pdf |
Originally Posted by jlchavis0844 ![]() Shhhhh.............Don't let the PSU snobs hear you, they will run you off the forum on a rail (12v with atleast 22A). |
