will this work?
1626 Views 63 Replies 7 Participants Last post by  Akisame
hey guys im new to AMD rigs and im wondering if this will work ok?
AMD Phenom II X4 Quad Core 940 Black Edition 3.0GHz (Socket AM2+) - Retail £197.79
(£171.99) £197.79
(£171.99)
Gigabyte GA-MA790FXT-UD5P (Socket AM3) PCI-Express DDR3 Motherboard £166.74
(£144.99) £166.74
(£144.99)
OCZ 2GB DDR3 PC3-10666C7 1333MHz Platinum (2x1GB) Dual Channel DDR3 (OCZ3P13332GK) £40.24
(£34.99) £80.48
(£69.98)
Sub Total : £386.96
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £9.50
VAT is being charged at 15% VAT : £59.47
Total : £455.93
1 - 20 of 64 Posts
No... the 940 is not supposed to be ddr3 compatable. its 1066 ddr2. But thats not a bad thing. The latency is better.
No it won't , get the 720/710 or 820 if you want to use that mobo+ram, because 940 is a AM2+ chip only
Nope. You can't use an AM2+ proc on that AM3 board.
damn i though am2+ ment am2 and above confussing! i was thinking about waiting for the 945 but my only pc is dying out slowly!
Well anything out now would be a huge upgrade from that.
defo its naff on its way out! i wouldnt be suprised if it died by the end of the month!
am3 cpu can be used with am2+/am2 mobos with a bios update.
am3 mobo can only be used with an am3 cpu.
just get a 720be if you want to go am3. you might even unlock the 4th core with that mobo anyway.
cheers
get teh Phenom II 810 for that AM3 board and the DDR3 RAM.
revised
(£144.99) £166.74
(£144.99)
AMD Phenom II X3 Tri Core 720 Black Edition 2.8GHz (Socket AM3) - Retail £123.98
(£107.81) £123.98
(£107.81)
(£34.99) £80.48
(£69.98)
Sub Total : £322.78
DPD Next Day Parcel
VAT is being charged at 15% VAT : £49.84
Total : £382.12
saves me some pennys to!
oh my, that tax and shipping can already give you a 4830.
nice, i forgot about unlocking the core on teh X3, that would be nice.
that a nice list.
if u got a 64bit OS, go for 4gb (2x2gb)
yeah sould be good!
ive got a 9500GT that will have to do me for a while till i get some more dosh!
yeah theres 2 sets of the ram in the list btw so 4gb and im going to stick with 32bit vista ultimate until i win 7 comes out properly!
yeah sould be good!
Why not go for x64 Vista? The disk from Microsoft is $10. You will be forced to reformat if you stay with that HDD.
Originally Posted by Akisame View Post
Don't get 4x1, get 2x2 instead...
+1
get a stick of 2gb first then buy another one soon. single channel is not that bad. just run it on ganged mode.
cool cheers for the heads up but the OCZ ram is on offer 20 quid off!
You should just get AM2+ , it will cost you less... Ram will run the same , cause ddr3 is faster , but has higher latency , while ddr2 is a bit slower, you get lower latency's .So go for phII940(or stick with 720 if you like), 2x2gb 800/1066 4cl/5cl , cause ddr3 is not mature yes, so the gain is not worth the extra you spend
cool cheers!
so will my 720BE work with a AM2 and DDR2?
1 - 20 of 64 Posts
