1 - 14 of 14 Posts
Originally Posted by TheSubtleKnife
I have it too, a stuck white pixel in the lower right hand corner, only happens in BC2
same here.
I can't remember whether I've only seen it between map changes or when you pull up the class screen.
I know what the OP is talking about. Like when you enter that Heavy MG turret, where the black bars are on the bottom of the screen, there's one noticeably white pixel in the bottom-right corner.
FWIW, I use a 10:16 monitor.
Swing your knife.... does it go away? If so, it's the gun skin. i.e. There are other "dead pixels" undernearth your iron sight in the pic you posted.
I have the same dead pixel. At first I thought it was my screen having a dead pixel I never knew about, but then I double checked to make sure it wasn't there on my desktop and it wasn't.
As long as you're in first person view, I think the dot is there. Perhaps it's a piece of the HUD they accidentally put in?
I'm gonna need a sweeper
I have it too, usually on the menus. Its a random bug - might get fixed but its only 1 pixel so not too much of a problem.
1 - 14 of 14 Posts
