Win 7 64bit sluggish
1960 Views 12 Replies 9 Participants Last post by  ComGuards
I installed win 7 a couple of weeks ago and just am not happy,
everything is sluggish and internet pages come in 2 to 3 times slower that with
Vista ultimate 32bit.
So i went ahead and ordered 8 gig's of Kingston Hyper x 1066 Mhz (4 dimm's),
do you guys think these will help.
1 - 13 of 13 Posts
I guess. Windows 7 utilizes resources much better than Vista did, so I don't really think 4GB of RAM was the problem (heck I'm doing fine on this jalopy with 2GB DDR)...
You know about ccleaner and auslogics disk defrag, oh and check this out it applies to 7
www.opendns.com
http://www.speedguide.net/read_articles.php?id=2574
I recommend scrolling down and save target as auto optimization that they provide. You have to do it in IE browsers for some reason it doesn't work in firefox for many people. I may also suspect a virus or something of the sort. www.download.com try malwarebytes anti malware in safe mode
Originally Posted by dudenell
new install or upgrade? If so have you tried a new install?
^ if you didn't do a clean install some people have problems with upgrading.
Seeing how Windows 7 is a bit slimmer than Vista, I agree; Back up your stuff and do a clean install if you haven't. If you did, it really should not be slower. Have you analyzed the disk to check the fragmentation?
Or even a quick speed check is to go to system, advanced system settings, Performance / settings, then advanced settings, and increase the size of the paging file. It's not as quick as ram, but will give you a quick boost and show you if Rams going to be a huge improvement. I was running fine on 6 gb, and my wife fine on just 2gb. I set my initial page file size to 2048 and max at 4096.
I have a feeling this was a fresh install. Just a shot in the dark, but I'm taking the HDD route here. Make sure write-back is enabled, defrag, check virtual memory settings.
Also, just FYI on the 8GB RAM; Win 7 will use more if there's more to be had. Only using ~700MB at desktop currently, but when I had 8GB installed on my previous rig it would use ~1.5GB
Ya i did a clean install.
Where do i check for the write back setting,bios?
what? no way man. i find windows 7 a whole lot faster and more responsive than vista. there should be something wrong, perhaps with the drivers or the installation itself.
he's talking about write-caching..its under the hard drive hardware under device properties and under policy tab...its usually enabled by default.
if its noticeably sluggish probably malware/virus.
Unless you're running 512mb RAM right now, 8GB of RAM is not going to help firefox load faster lol.
Dumb question... but I have to ask it, since nobody else will.... Have you monitored your system to check for CPU and I/O usage? If there's something beating the crap out of your CPU and / or disks, you'll be slow all over the place...
1 - 13 of 13 Posts
