1 - 3 of 3 Posts
In my setup I use 3 partitions. I have one for os, one for apps, and one for storage.
I'm using Windows 7 and was just wondering which of the following would be best:
ScenarioA - I can change my Apps partition to drive letter C:, so that stuff defaults to install to it
or
ScenarioB - I can change the registry so that drive letter D: (my apps partition) is the default install location
Does anybody know if there are any advantages / disadvantages for doing it one way or the other..or does it matter at all?
Originally Posted by sn0man View Post
It doesn't matter at all, and there won't be any advantages or disadvantages either way.
Your C drive will always be your OS drive though.
Yea it's not letting me change it. Registry change it is!
Thanks
1 - 3 of 3 Posts
