1 - 6 of 6 Posts
Never had this problem before. I changed mobo, cpu, and ram. Everything else is the same.
Ive done everything with drivers, windows updates, and everything how-to off the web.
When I click shut down, the video feed shuts off but the pc is still on.
Also restart takes forever when it works.
Da Boss
I think you have bigger problems than that. This post is riddled with "s".
Not sure if it's the PC you are using or if it's OCN, but I suggest clearing that up first before anything else.
Sir Loin
Its OCN i have been having the same problem when posting from mobile then viewing on desktops.
which you can see in my current thread
here
https://www.overclock.net/forum/297-general-processor-discussions/1727942-i7-7700k-wait-buy-into-zen2.html
For the OP
have you you reset bios to optimal default
maybe a bios update too
Have you tried f8 on boot then repair
Discussion Starter #4
I'll give a another try narr.
Discussion Starter #5
Still no go. I didnt add any software so if it is a program causing the problem, I have no clue to what it would be.
Discussion Starter #6
1 - 6 of 6 Posts
