Win7 Download Folder
594 Views 5 Replies 4 Participants Last post by  kidaquarius
Is there a way to transfer the downloads folder on another partition without transferring the whole users folder?
1 - 6 of 6 Posts
If I am interpreting your question correctly, would you not be able to use any one of the OLE-techniques (i.e. cut and paste)?
There certainly is! Check this out:
  1. Right-click on the folder and choose Properties.
  2. Choose the Location tab.
  3. In here, you can either just type the new location and press Enter, or click Move...
  4. If you just type the new location then press Enter, it will ask you if you would also like to move all of the files to the new location as well.
This way you change the location of this special folder. Then when you want to move it again, right-click on the new location and do the same thing.
Reactions: 2
great thanks! +rep man. didn't bothered to check the properties since i thought its built in within the user folder :/
Aw, it's all good man. I owe it to my experience with TweakUI XP which allowed me to do this same thing. So when I came to Windows 7, I kind of desperately searched for a way to do it again.
Haha.. My thoughts exactly!
1 - 6 of 6 Posts
