1 - 5 of 5 Posts
I have
--AMD Phenom II x6 1055t
--gigabyte GA-890GPA-UD3H
--GSKILL PI F3-12800CL6D-4GBPI 2gbx2
ANd --Seagate 500gb 7200
and i m trying to install windows 7 32bit! and it says that : "the partition can not be created! "
can anyone help!!???
Not new to Overclock.net
Originally Posted by virang.dalal View Post
I have
I'd like to try to help.
When you see this message, at what part of the installation does it occur?
Do you have a USB thumb drive plugged into the motherboard?
Also, try reformatting the drive using SeaTools.
Are you plugging your drive into the blue or the white SATA ports on the board?
Also, is this a brand-new drive? If not, you might have old partitions on there or something similarly funky going on that's not allowing the W7 installer to create partitions properly. In that case, just download Parted Magic and use gparted to completely remove all disk partitions.
1 - 5 of 5 Posts
