I installed win7 to my first ssd last night and was going crazy disabling stuff, but now when I use the search function in the start menu, it doesn't work as it should.
If I put in user accounts, for example, it pops up. However, msconfig and regedit do not. I have to go to the windows folder and find them manually.
Funny thing is, this didn't start after the first reboot after changes. It started two or three reboots later.
I tried using services.msc to re-enable windows search, but it said the path was invalid. I went and found searchindexer(what the filepath was pointing to) and it was right where it is supposed to be.
Will a couple more reboots fix it?
Is there something else I need to re-enable?
