1 - 2 of 2 Posts
is there a way that i can get rid of the doubles in my winamp media library?<br />
other than going in and selecting them one by one and getting rid of them
<a href="http://members.cox.net/eqreed/ml_plfix.zip" target="_blank">http://members.cox.net/eqreed/ml_plfix.zip</a><br><br>
Install this into your C/Program Files/Winamp/Plugins folder and restart Winamp<br><br>
and open your media libary - on the lft side with all the other options you should see "�gen_plfix"<br><br>
Run it and It will find the following<br><br><div style="margin:20px;margin-top:5px;">
<table border="0" cellpadding="6" cellspacing="0" width="99%"><tr><td class="alt2" style="border:1px inset;">�Auto Fix� is the same as �Hand Fix�, except it will automatically fix missing files with one and only one candidate. (If multiple candidates are found, you still have to pick it by hand.)<br><br>
�Find Duplicates� will scan your media library for duplicate files, and allow you to delete them if you wish (right click on the files)</td>
</tr></table></div>
Hope this helps <img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
1 - 2 of 2 Posts
