1 - 2 of 2 Posts
Number of CPUs 1
Name AMD Athlon XP
Code name Barton
Specification AMD Athlon(tm) XP 2500+
Family/Model/Stepping 6A0
Extended Family/Model 7/A
Package Socket A
Technology 0.13µ
Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE
Clock Speed 1830.0 MHz
Clock multiplier x11.0
Front Side Bus Frequency 166.4 MHz
Bus Speed 332.7 MHz
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 512 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 1830.0 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 64 bits
Northbridge nVidia nForce2 Ultra 400 rev. C1
Southbridge nVidia nForce2 MCP rev. A4
AGP Revision 3.0
AGP Transfert Rate 8x
AGP SBA supported, not enabled
AGP Aperture 64 MBytes
Memory Type DDR
Memory Size 512 MBytes
Memory Frequency 199.6 MHz (5:6)
CAS# 2.5
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 8
When using MBM5 to measure temps should I set CPU sensor to Winbond 2 or Wimbond 3? Winbond 3 shows stable temps of around 42 degrees when idle (without any overclocking) and Winbond 2 shows temps of around 50-52 degrees without any overclocking.
Originally Posted by fahadrulz
Number of CPUs 1
Name AMD Athlon XP
Code name Barton
Package Socket A
Technology 0.13µ
Bus Speed 332.7 MHz
L2 Location On Chip
AGP Revision 3.0
Memory Type DDR
CAS# 2.5
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 8
I would compare the Winbond temps to the temps in your BIOS and choose which ever Winbond temp is closest.
1 - 2 of 2 Posts
