1 - 16 of 16 Posts
The cooler master store would be your best bet.
From what I can tell, they don't have it,
According to a guy on ebay, you can't even get them anymore! Say it ain't so!
Edit: Second link I found was right to the panel. Guy on ebay was full of ****
Okay I'm bumping this thread with a question. Where else can I get this piece? The CM store is out of stock and every rep I've talked to about it has been incredibly rude.
Maybe ebay, when I was looking for a HAF 912 advanced and my HAH 932 windowed side panel(the one with the dragon) I had to keep checking each day for a few months before they came into stock, then immediately order. A few days later they were out of stock again.
Man that must've been maddening. It sucks because my build is 90% done, and that side panel is a big part of it
The ONLY vendor on ebay that has them is in the freaking Netherlands
Ya it was, lol. The case was only released in asia, at first. I was almost ready to buy a regular 912, paint it and buy the usb3.0 adapter, fans and drive latches separately.
The panel I just really wanted, luckily I was able to use the rig just fine while waiting.
Discussion Starter · #9 ·
Well yeah, the case is perfectly functional. You just can't see any of the internal LED's or my nice cable management
If I was you I would just leave the panel off so I could admire my components, unless you have alot of dust or animal hair around.
Discussion Starter · #11 ·
Haha two cats and a VERY curious two year old
Lol, nvm then.
Discussion Starter · #13 ·
Yea I accidentally stuck my finger in my gpu fan and took a HUGE chunk of skin out. I hate to think what would happen to my daughter's finger.
I did that on a 6970 and broke the fan. But ya definitely don't want any little fingers in there.
Just check every day( i just kept a tab open) to see if it's in stock. Odds are that it wont be to long.
Discussion Starter · #15 ·
Yeah that's my last option, they keep telling me different things, so I'm not sure what to expect.
1 - 16 of 16 Posts
