1 - 2 of 2 Posts
ok i have been using combofix for a long time and it the best program out there. I call it my magic tool lol. but its only good for 32bit os and they are getting few and far between the BestBuy i work at doesn't even carry 32bit in store. So what is good freeware to fix missing .dll and system files??? i have been looking but most uyou need to pay for or the others just arent that good if anyone knows a good program or programs that would be awesome. Also can you make the program bootable?
(virus)
IF you can boot into windows you can just use sfc.exe (system file checker). Compares files on the disk to the windows files installed on the dvd and repairs as its needed.
http://www.hiren.info/pages/bootcd
Excellent boot cd. Loads of tools on it.
1 - 2 of 2 Posts
