Hey guys i've built a server for someone and the program they use will only run on a 32-bit operating system... can i just install the 32-bit and transfer the icons without wiping out the whole server?
Originally Posted by MiniTuckin
if you try and install it, it just keeps saying it will not support 64-bit... i've tried running it in every version of windows
Also how would i go about partitioning off a small part of my current hard drive to install 32-bit. I dont wanna format it all and lose my information thats already on there
Pathways is a VERY embedded System. Proceed with caution, because if you are dealing with an existing system, and you make one wrong move, you can crash their entire customer database with the push of a few buttons.
Probably not, ideally you'll want 2 harddrives... if not, maybe copy everything you want to keep onto an external drive then install 32 bit then reinstall applications, then copy the data back on.
1 - 12 of 12 Posts
