i would not think so, but if you are planning on going to 4gbs of ram soon, i would install the 64bit if you can.
Originally Posted by videoman5 ![]() No, I was pointing out the fact that the genuine check can be disabled. It goes against the the EULA, but is not illegal as the EULA is not seen as a binding contract by the courts. |
Originally Posted by TwoCables ![]() Oh. But you didn't say anything. You just bolded a couple of things and posted it. Well, I don't care. I am not about to suggest doing that. That's not how I roll. So again: if his friend is using the Product Key and if he has already activated it, then this should not be attempted. I am not going to suggest any work-arounds because enabling this 1 Product Key to be used and Activated by 2 different people is software piracy. I'm not about to risk getting an infraction, ok? |
