Table of Contents:
Post 1 - Introduction and set up
Post 2 - Setting up HFM to monitor your client
Post 3 - Adding/Removing Folding slots
Post 4 - Additional client configurations ("flags")
WIP:
Post 5 - Connecting multiple rigs to one client
Post 6 - Configuring separate passkeys for individual slots
Post 7 - Understanding Client v7 (for experienced users only)
This guide will outline the steps required to set up the Unified Client for [email protected], to configure it to Fold for Team OCN using your CPU and GPU(s), and to track it all using the monitoring program HFM.
For multicore CPU Folders, be aware that SMP WUs have bonus points, with more bonus points the faster you finish the WU. However, the bonuses only come into effect after you have completed 10 SMP WUs. Again, you will need to submit 10 SMP WUs before you begin getting bonus points.
What you'll need to begin:
1) The Windows Folding Client v7; Select v7.3.6.
(Direct Link)
2) HFM.NET; under "Featured Downloads".
(Direct Link)
3) An AMD GPU, with Catalyst v11.1+. Or a CUDA supported nVidia GPU (list here), with 266.xx drivers or newer.
4) A Folding passkey from Stanford. You can request one from here.
Client Setup:
1) Run the install file for the Folding client, Click Next, then 'I Agree' to begin the installation. When prompted, choose "Custom install".
I leave this on 'Install just for me', but choose whichever option you would like:
Now, install the client to the default location (Or specify your own location if you prefer to install it to a non-OS drive):
For the next screen, leave all settings on the "Recommended" options.
And then Finish.
2) Next, your web browser should open to the [email protected] client initial configuration. Click 'Configure Identity', then enter:
• Donor: [Your Folding Name] (Check here to see if your preferred name is in use.)
• Team: 37726
• Passkey: [The passkey you requested earlier]
Click Save, and the client will start folding on 'Medium Power'.
You should see something similar to this:
That is the 'Web Control' interface, you should also see a [email protected] system tray icon.
As I mentioned by default the client initially starts at Medium Power, here is an explanation of the Power Slider in the Web Control:
The slider has six preset positions:
Now I always use 'Full' because I like my GPUs to fold primarily. To me the 'Web Control' isn't very useful, and I prefer the 'Advanced Control'.
To open 'Advanced Control' right-click the [email protected] System Tray icon, and select 'Advanced Control'.
You should see something like this:
Go ahead, and move the slider to Full to fold on the GPUs as well as the CPUs full time if you like. If you want to remove the CPU, and just fold on GPUs, in 'Advanced Control' click 'Configure' -> slots tab -> Highlight the CPU slot, and click 'Remove', then save.
WIP:
(Direct Link)
(Direct Link)
Client Setup:
And then Finish.
• Team: 37726
Off | Folding is disabled |
Idle light | Folding will proceed at a reduced speed only when your computer becomes idle. |
Idle | Similar to Idle Light, but tries to get the maximum productivity from your computer only when you are away. |
Light | Folding proceeds at a reduced speed at all times, but productivity and system utilization increases when you are away. |
Medium | Much more productive than Light. This setting is recommended for most users. |
Full | Contribute as much as possible. This setting may cause some machines to get hot or the fan to run very hard. If this is a problem simply move this slider to a lower setting. |
