Windows 7 backed up everything for me?
506 Views 7 Replies 6 Participants Last post by  Yoshimanitsu
Everyones been telling me a clean install is all you can do. I'm cool with that, so I back up all my stuff on my laptop, which took 5 hours. then installed.
Windows.old file with all my old stuff I didn't back up, right in it.
Why the hell did I do all that backing up?
1 - 8 of 8 Posts
Well if you have windows xp, then you have to do a clean install. But if you have vista, you can do an upgrade. I think, when most people do an install, they have the installer wipe the disk clean before installing... which would erase all files. But if you just select a drive with data on it, and hit install without telling it to erase the disk, it'll put it all in a file.
This was the case with vista as well.
If your power went out during an upgrade I think you would lose it all.
see the thing is, it asked me if I wanted to upgrade or clean install and i tried upgrade and its like "NO SCREW YOU MUAHAHAHAHHAHAHAHAHAHA"
and I was like ok clean, so i formatted during, then it was still there.
and I was using the w7 RC
Originally Posted by carl25 View Post
how exactly did you back it up ?
Using the network I sent it to my laptop
(was installing on my gaming desktop)
1 - 8 of 8 Posts
